Oil Pressure Light
Bobkennedy
, Jun 22 2018 10:01 AM
6 replies to this topic
Posted 22 June 2018 - 10:01 AM
I’ve just carried out a full service and have just noticed that the oil pressure light is no longer lit on ignition before starting. I had thought it should come on then go out once running. Is this correct?
I have 2 sets of clocks so relatively happy it’s not the voltage stabiliser. Any suggestions?
The heater gauge is working. Fuel I’m unsure as the car only has a Gerry can in at the minute and not currently road legal.
Posted 22 June 2018 - 10:24 AM
Might sound stupid but the connector is on the sender? I’ve knocked mine off before when working on the car
Posted 22 June 2018 - 10:26 AM
and have you checked the bulb.
Posted 22 June 2018 - 10:42 AM
I’ve just replaced all bulbs in the unit. That was my first thought.
I’ll check the connection on the sender shortly.
The only other thing to note is that the battery light comes on after revving, however measuring the voltage over the battery it’s a steady 14.3. Again on both sets of clocks.
Just to add Nippon clocks
Posted 22 June 2018 - 11:21 AM
Disconnect the wire that goes to the sender and short the wire to Earth. With the key on, the Oil Light should come on.
If it does, then the sender is suspect. If it doesn't then you have a wiring issue, a broken track on the PC board on the back of the clocks or an issue with the bulb.
Posted 22 June 2018 - 01:09 PM
Well don’t I feel like an idiot.
Oil switch connector was stinking. Good clean and all works agaun
Posted 22 June 2018 - 06:50 PM
Good when it's an easy fix
Glad you're all sorted.
