I take it that if the knuckle joint rubber is not attached to the nylon cup its a mot fail? I have refitted the front ones on the van but they have come off again, is there something to make them more supple or am i wasting my time and need to replace them all?
Knuckle Joint Rubbers
Posted 24 June 2018 - 08:47 PM
Posted 24 June 2018 - 09:44 PM
Are the rebound rubbers under the top arm in place and in good condition? This will help stop them coming off, otherwise If they keep coming off they probably need replacing and yes they'll likely fail the MOT if not on properly.
Posted 24 June 2018 - 09:47 PM
the bump stops? they are a bit tired it hink but not sure...
thanks
Posted 25 June 2018 - 12:57 AM
Just to clarify, Unburntfuelinthemorning is referring to the Rebound Stops, they are the L shaped little pads.
With the aftermarket ones when I used to use them, I used to fit a small cable tie around the outer lip of the boot to stop them coming off, but, if the Rebound Pad isn't in place, then you can expect them to come off.
Posted 25 June 2018 - 05:32 AM
Also the quality of these rubber dust covers is horrendous these days - perishing after less than a year! My original 35 year old ones are now back on.
Posted 25 June 2018 - 07:08 AM
small cable tie stops them popping off
Posted 25 June 2018 - 08:34 AM
Very tricky to get them on properly... all I'd say is, try and get the void between the arm and the nylon seat as clean as possible so the rubber boot has something to cling on to. I use a radiator hose tool to coax them into position, it's like a screwdriver but with a curved end.
Regarding the MoT, I'd hope your tester is 'au fait' with Minis and classic cars. While the rubber not being attached is not ideal, in use it's pretty well squashed into position and I've never had one fill with water/ road muck. My man would not fail the car if this little boot wasn't fitted quite right...
Posted 25 June 2018 - 10:00 AM
Posted 25 June 2018 - 12:29 PM
Posted 25 June 2018 - 06:01 PM
right thanks! There is no form of lock wire on it now, there was a little band originally?
Ill use some lock wire and put them back on! thanks!
Posted 25 June 2018 - 07:53 PM
No, they don't have anything on them as supplied.
