Gearbox / Clutch Issue
Best Answer Bell-nose , 26 June 2018 - 08:21 PM
Fixed it - air lock in the slave. :) thanks for your help
Go to the full post#1
Posted 26 June 2018 - 04:57 AM
The car has no working gears! Symptoms as follows:
Gears can be selected - all are selectable in the box while the engine is off BUT there is no drive on the wheels. You can’t turn the engine over by hand by turning the wheels.
New clutch, flywheel and boss
New slave
New master
New bearing
Clutch arm moves and is set up right
All gears are there without depressing the clutch while the engine is off
Can anyone advise where the issue lies? It’s as though the clutch is permenantly on / off and I have a box of neutrals.
Posted 26 June 2018 - 05:38 AM
What mini are we talking about here? Model, year, engine size etc etc Verto clutch, pre verto clutch, BMW head conversion.
Need more info - talk about bare shell but did you rebuild the engine and gearbox too?
Posted 26 June 2018 - 05:46 AM
Engine works fine I.e starts and runs clutch rotates on primary gear by hand when I was setting up.
As I said I would expect to put the car into gear and rotate the wheels to set the valves but it’s not happening even though I can select all gears inc reverse without using the clutch.
Edited by Bell-nose, 26 June 2018 - 05:48 AM.
Posted 26 June 2018 - 06:39 AM
Hi,
Just checking, you have got one wheel on the ground haven't you?
Posted 26 June 2018 - 12:37 PM
Maybe you left the idler gear out or the main shaft pinion gear out, or the diff is u/s
Posted 26 June 2018 - 08:21 PM Best Answer
