Mini parts clear-out, collection preferred from Milton Keynes, flexible on prices (will be tipped otherwise) and offers on anything in the pics not listed.
Headlamp buckets with wiring, headlamp buckets mounting holes have had it, but sound wiring, bowls, retaining rings and fixings £10
Plastic headlamp buckets, covered in primer, useful for fixings, £5
Chrome headlamp rings (x4) £5 each
Boot lamps, one chrome (some pitting) £5 each
Side indicators with wiring attached, £5
Front indicator, £5
Headlamp gaskets (x3), boot lamp gaskets (x2), mk4 rear light gaskets (x4) £2 each
o/s rear lense, clear indicator lenses (x3) orange indicator lenses (x2) £1 each
Lower dash rail, tatty, been painted but otherwise sound, would be ideal for recovering, £5
Dash rail trim, £5
Dash top air vents, £5 each
Chrome switch panel with switches, £20
Switch panels (x4) £4 each
Headlining rods, white (x2), blue (x1), £8 each
Grey door winders (x4), winder rings (x2), lock plates (x3), door pull, handle, £2 each
Gear knobs (x3) £4 each
Handbrake, £10
Air vents, trims, eyeball vent and retaining ring, £10 each
Unknown rectangle vents, £5
Rear view mirror, £5
Rear ash tray bracket, £2
Lower bonnet trim (x2) £5 each
Lower grill trim (x3) £4 each
Inner/outer weather strips various (one mk3 inner) £2 each
Pair of outer weather strips, £10
Locking rods, long (x2) short (x3) £5 each
Door mirrors, £10
Fake filler neck, £2
Door scratch plates (new) £4
Seat adjuster brackets (new) £4
Plastic fans, 5 each
Washer bottles (one with pump) £5 each
Wiper motor cover £2
Washer bottle brackets, £5 each
Wiper motor parts, racks, motors, offers
Standard rear trumpets (x5), front trumpet, £5 each
Standard rear radius arm brackets, £5 each
Steering rack u bolts, £5
Rear subframe mounts, £10
Engine (x5), subframe mounts (x2) £2 each
Drive flanges, £15
Gearbox/engine mounts (x3) £15 each
Donuts, (x3 pairs) £15 per pair
Rocker cover £10
Radiator (x2) £15 each
Seatbelts, black pair with bolts and storks £20,
Grey pair with bolts and storks, £10
Single black seatbelt stork, £5
Standard air box, £10, air box lid £5
13” steering wheel with boss, £20
Rear window, boot (late type), quarter light (opening), door and door window seals, £2 each
Set of painted standard arches, £5
Single black painted arch, £2
Heater feed hose, £10
Screen demister vents, £5
Ring spot/fog lamps, with bulbs, wiring, stone guards and covers, £20
Interior light, £5
Rover cover t bars £5
Chrome/standard wiper wheel box bezels, £2 each
Poly rear damper top bushes, £4
Standard door mirrors, £10
3 clock dash bracket, £10
2 clock Nippon dials, £20
2 clock smiths dials (spares) £10
3 clock Nippon dials, £30
Mk 1 grill tash, has cut outs for bonnet catches and been painted matt back, £10
Front seam trims, £10
Door card clips, set of 18 (new) £3
Door pockets (x3) £10 each
213 Blmc Mini Cooper and S, Elf, Hornet 1959 -75, £10
213 Blmc Mini Cooper and S, Elf, Hornet, clubman, 1275 gt 1959 -78, £10
