Webcon Alloy 7 Port Head
13 replies to this topic
#1 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 02 July 2018 - 08:05 PM
I have decided to sell my 7 port head. It is a webcon version that is the same as the pierce moulds.
I haven’t run the head on the road but it has been on the engine and run for a short time (1/2 hour max). It is as supplied by webcon. I had it on twin 40 Weber’s which bolt directly to the head using misab plates. It fits under a standard non flip front round nose with short trumpets on the Weber’s. I am only selling as I have decided to go down the forced induction route which I already have the head for otherwise I would have had this one re machined.
I’m located in Halstead Essex but still have the original packaging so I am happy to post at buyers expense. £1000 no offers.
Any questions just ask. Link to the head from webcon http://www.webcon.co...opexd.asp?id=35
#2 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 02 July 2018 - 08:26 PM
Got any photos of the ports?
#3 bluemini1979
bluemini1979
  • 619 posts
Posted 02 July 2018 - 08:32 PM
Inlet, exhaust ports or both? I can stop by my workshop tomorrow and get some for you.
#4 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 02 July 2018 - 08:33 PM
What cc are the chambers
what size valves does it have
#5 bluemini1979
bluemini1979
  • 619 posts
Posted 02 July 2018 - 08:43 PM
Inlet valves 33mm exhaust valves 29mm. Chambers are 23cc
#6 screech
screech
  • 3,136 posts
Posted 02 July 2018 - 08:45 PM
Both please.
You sure inlet valves are only 33mm?
#7 screech
screech
  • 3,136 posts
Posted 02 July 2018 - 08:49 PM
#8 bluemini1979
bluemini1979
  • 619 posts
Both please.
Yeah I’m sure they are I can re measure them tomorrow for you.
#9 mini13
mini13
  • 3,805 posts
Posted 03 July 2018 - 11:32 AM
33mm is the standard size finlet valve for these, although a lot of users put larger in there.
OP could always turbo the 7 port..... :D
#10 paulk 7364
paulk 7364
  • 206 posts
Posted 03 July 2018 - 02:16 PM
Hi, what I need to do to use this on my 1275 engine
Hiff 44 carb sw5 cam . What sort of bhp could I achieve
With the wright parts ?
Thanks from a not a well informed mini enthusiast
#11 bluemini1979
bluemini1979
  • 619 posts
Posted 03 July 2018 - 04:06 PM
To use on Your engine you would need to source suitable Weber carbs or throttle bodies if you wanted fuel injection, sw5 should work well as that is what I had in mine. Power wise you would make more than what your 5 port is making as long as it is set up well.
#12 bluemini1979
bluemini1979
  • 619 posts
Posted 03 July 2018 - 06:54 PM
Photos of the ports
#13 screech
screech
  • 3,136 posts
Posted 03 July 2018 - 10:24 PM
Thank you.
#14 Boom!
Boom!
    Starting My Mini Up
  • 3 posts
Posted 12 July 2018 - 08:54 AM
Do you still have this?
