Headlight Issue! Where Do I Start?
Posted 05 July 2018 - 08:24 PM
Got an issue with my headlights.
When I turn the switch to sidelights I get both side lights on plus the left hand full beam.
When I turn the main beam it stays the same but the right hand main beam doesn’t work. (Tried changing the lamp)
If I use the full beam the left hand goes off and the right hand comes on.
The wiring isn’t very good so I wondered if its worth just ordering a new wiring loom for the lights and starting again?
I have a multimeter but not sure what to test first?
Again very new to minis so apologies for lots of questions ?
Posted 05 July 2018 - 08:49 PM
If there is power on the circuits to the light, check the bulb
What year of mini?
Edited by cal844, 05 July 2018 - 08:50 PM.
Posted 05 July 2018 - 08:52 PM
It’s a 92 Mayfair
Posted 05 July 2018 - 08:56 PM
Posted 05 July 2018 - 08:58 PM
Hi,
Sounds like a bad earth, most likely the clump of bullet connections by the bonnet catch.
Posted 05 July 2018 - 09:10 PM
I’ll have another play tomorrow night see if I can find it
Posted 05 July 2018 - 09:33 PM
Sidelights - red
Dipped beam - blue/red
Full beam - blue/white
Earth - black.
The sidelights and headlights share a common earth each side that then merges by the bonnet catch and onto the inner wing.
Therefore if the sidelights work both sides its unlikely an earth issue .
Id bet someone's messed about and mixed up the wires.
[email protected]
Posted 06 July 2018 - 06:37 AM
Make sure someone hasn't connected things wrong / badly by the bonnet catch.
Sidelights - red
Earth - black.
[email protected]
thanks will have a look tonight
Posted 06 July 2018 - 11:24 AM
Pop the switch out and look at that too. The connectors have a habit of melting. In general, just run through the wires, lights are very simple.
Input:
Brown wire to Switch
Sidelights:
Switch to Red wire to Fusebox to Red/Green wire to Sidelights, tail lights and dash illumination
Main/Dipped is a little more complicated so break it into a few parts:
Switch to Blue wire to Stalk
Stalk to Blue/Red wire to Dipped lights
Stalk to Blue/White wire to Main beam and dash tell-tale
Stalk to Blue wire to Inline Fuse to Blue/Orange wire to Fog light switch to Blue/Yellow wire to Fog light and tell-tale
There is also the purple wire into the stalks which allows Main Beam to be used separately (flash) but that's not part of your problem.
Edited by Icey, 06 July 2018 - 11:25 AM.
Posted 06 July 2018 - 03:04 PM
thanks ICEY. that's really helpful. I will take a picture of the mess under dash when I get home
