Hi all,
I'm sure this question has been asked before but hopefully you don't mind me asking agian. Would 12x5.5 wheels fit on a 1986 Mini, the current wheels are 12x4.5 with room to spare around them they also have an offset of around +35 if i calculated correctly. The wheels i am interested in have an offset of +10. The mini has had the suspension redone however this has not affected ride height to my knowledge.
Thanks for reading.
4 replies to this topic
Posted 06 July 2018 - 12:05 AM
Posted 06 July 2018 - 01:54 AM
Yes, they will fit on the car. However they'll stick out 38mm further than they do now, so you may need to get some wider wheel arches to cover the tyres
Posted 06 July 2018 - 07:06 AM
In your opinion are group 2 arches sufficient?
Posted 06 July 2018 - 09:41 AM
yes group 2 ok have them on mine 5.5 wheels stick out a bit tho not much. ultralite do a -20 so 10mm less stick out
Posted 07 July 2018 - 10:38 AM
These just listed
http://www.theminifo...p-2-arches-new/
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
