Unless I'm being thick I can't find anyone with a 998 Primary Gear Shim in stock measuring 0.120 - 0.122" so wondering if anyone on here has one I could buy.
Posted 08 July 2018 - 01:31 PM
Posted 10 July 2018 - 08:33 AM
I may have one, ill check Latter I have 2 or 3 in the garage.
Posted 11 July 2018 - 01:14 PM
Hi Pal..
The thickest I have is 0.114, you may need to look at changing your retaining ring and C clip, as most Engin builders will take any tension in the primary gear away by taking material from this part,
look at getting a new ring and C clip, I have one if needed.
Regards
Rick
Posted 11 July 2018 - 05:15 PM
Hi Pal..
Regards
Rick
Cheers mate, think I will have to look into getting a new c clip and ring then as even with the thickest shim it'll still be at the top of the range. Think I'll buy them gen new as they are only peanuts but thanks for looking.
Posted 11 July 2018 - 09:54 PM
Cheers mate, think I will have to look into getting a new c clip and ring then as even with the thickest shim it'll still be at the top of the range. Think I'll buy them gen new as they are only peanuts but thanks for looking.Hi Pal..
Regards
Rick
