Hif38 What's This Hose For......?
Best Answer Retroman , 09 July 2018 - 12:23 AM
Its the breather for the float chamber
Will also dump petrol in a safe place if the float valve does not work
Not sure how long the clear pipe will last, it should be a nitrile rubber pipe
Go to the full post#1
Posted 08 July 2018 - 11:25 PM
Looking at a HIF38 carb in situ there is a hose on the left that points up slightly and a small diameter hose/pipe is connected to it.
What is this for,on my mini the pipe joins a solid pipe connected to the bellhousing but then does not go anywhere...
Does this seem right..??
Thanks all
Posted 08 July 2018 - 11:27 PM
picture may help.
vac pipe to engine is an out there guess.
Edited by nicklouse, 08 July 2018 - 11:27 PM.
Posted 08 July 2018 - 11:48 PM
IMG_20180708_174628523.jpg 52.58K 1 downloads
IMG_20180708_174624580.jpg 49.36K 1 downloads
IMG_20180708_174619808.jpg 35.33K 1 downloads
Its the clear hose in the first pic..
The bottom pic shows where the hose ends..
Posted 09 July 2018 - 12:23 AM Best Answer
