Advice Please ;) Again
13 replies to this topic
#1 Hector76
Hector76
  • 117 posts
Posted 09 July 2018 - 01:24 PM
The rubber at the bottom of his joint (at the rear of the photo) is perished
Can I replace it and what do I need to buy
Thank you guys , learning as I go along and finding new things as I am completing jobs
Kath ()
#2 nicklouse
  • 19,057 posts
Posted 09 July 2018 - 01:37 PM
you can get them seperatly
http://www.minispare...classic/knuckle .aspx|Back to search
 but I would change the whole unit as it is the same amount of work and if there is any crud in there they do wear fast
http://www.minispare...1A425.aspx|Back to
#3 Hector76
Hector76
  • 117 posts
Posted 09 July 2018 - 01:50 PM
Thank you so much for your help x
#4 Hector76
Hector76
  • 117 posts
Posted 09 July 2018 - 03:07 PM
Will I need any special tools to replace these , have orders a pair from the links shown. Thank you x
#5 nicklouse
  • 19,057 posts
Posted 09 July 2018 - 03:43 PM
i would get some PlusGas and get it sprayed one the adjusters on trumpet.  you will need to remove the rebound rubber to let the arm drop fully. spanners of the right size and you could be lucky and not need to compress the rubber dounut.
#6 Spider
  • 15,843 posts
Posted 09 July 2018 - 07:38 PM
If I can suggest, there's a few more items that need doing that I can see;- the Bump Stop has gone and the Rebound Stop looks really dead too.
Apart from these, I'd suggest from the general appearance of it all, to replace all the Rubbers.
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 09 July 2018 - 07:58 PM
you will also need to replace this http://www.minispare...x|Back to shop  single bolt
http://www.minispare...px|Back to shop
#8 Hector76
Hector76
  • 117 posts
Posted 09 July 2018 - 08:20 PM
Thanks guys , where is the bump stop located ? Has mine disintegrated so bad that I can’t see it ?
Have ordered new tie rod ends, tie rod boots/dust covers
Cv inner and outer boots and a pair of knuckle joints.
want to make sure I can get all the bits that need doing, I know I prob sound like a beginner here but if I know what it is that needs replacing and I can buy it and replace it myself.
Can’t thank you guys enough
Kath
#9 nicklouse
  • 19,057 posts
Posted 09 July 2018 - 08:26 PM
Kath
number 12
http://www.minispare...on~.aspx?1~8~66
#10 andyapanel
andyapanel
  • 651 posts
Posted 14 July 2018 - 03:26 PM
Beware the M6 at Knutsford-it tore off one of mine.
#11 Hector76
Hector76
  • 117 posts
Posted 14 August 2018 - 11:34 AM
What size spanner do I need to release the nut above the rubber please ?
#12 DeadSquare
DeadSquare
  • 3,382 posts
Posted 14 August 2018 - 11:58 AM
You may need two spanners, one to hold the nut above the rubber which is fixed to the thread while the other loosens the nut below the trumpet, which you then undo all the way down to the bottom nut. Then, turning the bottom nut, screw the whole lot up into a trumpet.
Get as much of that rust and crud out of the threads as you can before you start. I suggest wrapping oiled string round the threads and pulling it backwards and forwards.
I don't know the size of the nuts, but they look to be about 22 mm at a guess.
Edited by DeadSquare, 14 August 2018 - 12:00 PM.
#13 Hector76
Hector76
  • 117 posts
Posted 14 August 2018 - 01:59 PM
Thanks for your help , much needs info there !
I checked the nut size with an adjustable spanner and it’s 32mm, now gotta wait for my spanner to arrive, I have so many tools but never the one I need !
#14 Hector76
Hector76
  • 117 posts
Posted 19 August 2018 - 12:41 PM
Hi guys, I managed to undo the nuts and wind the nuts up but can’t get the knuckle out https://www.dropbox....G_0971.JPG?dl=0
Any advice or do I need to buy yet more tools ;(
