Center Of Gravity
7 replies to this topic
#1 cbh
cbh
    Starting My Mini Up
  • 4 posts
Posted 09 July 2018 - 06:26 PM
Hi
Can somebody please help me with center of gravity for a standard mk 3 body shell
Be Claus
#2 Retroman
Retroman
  • 855 posts
  • Local Club: CDMC
Posted 09 July 2018 - 11:52 PM
We need more of an explanation.....??
Do you want to;  lower it ?  find it ?  move it backwards ?
Why ?
#3 nicklouse
  • 11,329 posts
Posted 10 July 2018 - 12:18 AM
very little info out there. as above what are you needing it for?
#4 Moke Spider
Moke Spider
  • 8,258 posts
Posted 10 July 2018 - 12:46 AM
I'd guess it's to mount it on a rotisserie.
#5 cbh
cbh
    Starting My Mini Up
  • 4 posts
Posted 10 July 2018 - 05:07 AM
Hi All
Thanks for helping me.
Yes it is for mounting on a rotisserie so I need the height (from the floor) of the longitunal center of gravity line
Be Claus
#6 paulrockliffe
paulrockliffe
  • 1,662 posts
Posted 10 July 2018 - 07:55 AM
If you can't work it out, you could mount it in what looks about right, but aim a fraction low, then bolt some weight to the floor to balance it out.
#7 nicklouse
  • 11,329 posts
Posted 10 July 2018 - 08:32 AM
http://www.theminifo...tisserie-plans/
http://www.theminifo...-roll-over-jig/
http://www.theminifo...or-a-mini-spit/
http://www.theminifo...ing-a-90s-mini/
http://www.theminifo...ng-shell-stand/
some reading for you.
#8 Retroman
Retroman
  • 855 posts
  • Local Club: CDMC
Posted 10 July 2018 - 01:06 PM
The rota-dip holes are very high and you will find its no where near the COG, the lower section being a lot heavier than the upper section
The ones that bolt to the Front subframe mounts / rear shocker tops should have the rotation a lot near the COG
They make it a lot more managable when turning the shell to roast another bit
Mini Spares
