Mpi Failed It's French Mot On Emisions :-(
#16
Posted 16 July 2018 - 05:21 PM
I saw the HC reading and it was 470, if that means anything to anyone.
There are no leaks, I've sprayed easy start all around the inlet and no engine note change.
The old lambda was a bit sooty. The spark plugs are too.
All sensors are new and within spec so what would cause this ???
Anyone ???
Pete.
#17
Posted 16 July 2018 - 05:22 PM
#18
Posted 16 July 2018 - 05:52 PM
catalytic converters can die as well.Sometimes they are empty.Screw it off at one end and have a look into it, there are pictures on the internet how it should look like.
#19
Posted 16 July 2018 - 06:24 PM
Hi,
With the HC that high you're running rich, just need to find out why. What are you seeing on lambda voltage with the T4 now?
#20
Uk - for an mpi .3% co
Hc 200ppm
Edited by cian, 16 July 2018 - 07:31 PM.
#21
Posted 16 July 2018 - 06:29 PM
How does the T4 reset operate? With the ACR you can reset the learned values to default values. Has it be driven enough to relearn the new sensor values?
Terry
#22
Posted 16 July 2018 - 06:54 PM
Cian, I think you'll find that for an moi the limit is around 0.3%
Bat. The lambda on T4 is doing the same thing but it does say it should go up over 2.4v and down below 1v.
Tmsmini. I have deleted all learned values. Not really driven it much, probably about 10 miles in all.
#23
Posted 16 July 2018 - 09:37 PM
I hope you have got to the route of the problem.
For what it's worth, if your having idle speed issues, it might be worth checking if your MPI has had the Rover factory recall done regarding Rover tech bulletin 0043, an easy modification to do and available through Mini Spares/Mini Sports etc (YMQ105690) but symptoms normally point cooling fan being on continuously, but idle speed also affected. There are also some easy ways to reduce emissions slightly prior to MOT time and good practice: oil change, oil filter change, air filter change all helps to reduce emissions.
#24
Posted 17 July 2018 - 12:11 AM
You say all the sensors are new, does that include the idle air control valve and its hoses?
What about the purge valve, is it functioning properly? If it is open, would it cause a lean condition which might result in the ECU compensating for that?
Edited by tmsmini, 17 July 2018 - 12:48 AM.
#25
Posted 17 July 2018 - 05:51 AM
What is the purge valve ?????
#26
Posted 17 July 2018 - 06:03 AM
#27
Posted 17 July 2018 - 07:31 AM
#28
Posted 17 July 2018 - 08:41 AM
#29
Posted 17 July 2018 - 10:01 AM
And where's the purge valve that someone mentioned ?
#30
Posted 17 July 2018 - 10:06 AM
Hi,
Easy one first, the purge valve is on the triangle reinforcement panel right hand side as you're stood in front of the car looking under the bonnet by the wiper motor. Remove the hose that goes to the engine and plug it up.
A leak down test involves filling each engine cylinder with compresses air and then monitoring the gauge to see if there are any leaks.
