Mpi Failed It's French Mot On Emisions :-(
78 replies to this topic
#76 pete l
pete l
  • 1,358 posts
Posted 06 September 2018 - 08:09 AM
So, I have a new cat, new sensors, air intake, lambda, MAP, crank, coolant and 2 brand new injectors from minispares (sorry Alexmozza).
I have lapped the valves in and smoke tested the inlet to check for air leaks, none visible.
I've done a leakdown test and it is leaking down the bores.
All I need to do now is take it back for a retest.
Watch this space.
#77 Bat
Bat
  • 903 posts
Posted 06 September 2018 - 10:17 AM
Hi,
Watching!  :proud:
Cheers  :proud:
#78 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 10 September 2018 - 09:54 AM
You've re-honed the bores??
Excessive blow-by could foul the new cat you've just bought?
#79 pete l
pete l
  • 1,358 posts
Posted 10 September 2018 - 02:32 PM
No, not honed the bores.
I'm actually giving up on it as it is. I needed the french MOT so that I could get the log book in my name. No MOT here in france and you can't get the car in your name !
When there is a problem with the car during an MOT, you can sometimes get a 2 month provisional one, gives you time to fix the car. I managed to get the car in my name with the provisional MOT.
I will now pull the car appart again and continue the restoration. Hopefully when everything is finished, engine too, it will pass it's emisions test.
Pete.
