Coil Overs
Best Answer nicklouse , 10 July 2018 - 12:34 PM
there is so much wrong with the coil over kits. front and rear.
if you want a better ride fit new rubber donuts. if you want to lower it fit hilows.
Go to the full post
7 replies to this topic
#1 REDICE
REDICE
  • 44 posts
Posted 10 July 2018 - 12:21 PM
Im thinking about swapping my cones with a set of Protech coil overs. Has any one tried these? Do you need to run anti roll bars? Can the damper mounts handle the whole suspension loadings?
#2 CityEPete
CityEPete
  • 3,790 posts
Posted 10 July 2018 - 12:23 PM
On no wait for the replies!
No the mounts can't, but it won't stop people telling you otherwise.
#3 nicklouse
  • 11,328 posts
Posted 10 July 2018 - 12:34 PM   Best Answer
#4 grizzler73
grizzler73
  • 249 posts
Posted 10 July 2018 - 12:40 PM
Just do a search on this section of the forum and all will be revealed!
But the short answer is what nicklouse said...
#5 mini13
mini13
  • 3,089 posts
Posted 10 July 2018 - 12:43 PM
^^^ basically says it all,
coil overs can work, but it needs to be a properly sorted solution, personally Ive not had a lot to do with them, but a guy I know of hill climbs and held a few class records, he says its not even worth looking at the small diamater coil overs, go straight for th 2.25" ones as they damping works so much better, in which case  your looking at developing it from the ground up to get it to fit.
#6 DeadSquare
DeadSquare
  • 660 posts
  • Local Club: Herefordshire Motor Club
Posted 10 July 2018 - 01:19 PM
Abingdon tried adding shock-absorbers on a Hydrolastic works rally car.
The drivers reported that the only times that they could detect an improvement in the handling, was when they were airborne.
Apparently, just for the hell of it, they removed the shocks from a dry car, and the drivers dryly came back with the same comment.
This wasn't done in a rally, but it was over special stages where driving is "All arms and legs".
It emphasised that steel springs need damping, whereas rubber (although waterproof, Lol) is self damping.
#7 Cooperman
  • Mini Docs
  • 20,983 posts
Posted 10 July 2018 - 02:26 PM
What do you hope to achieve and why do you think coil-overs will do it?
Edited by Cooperman, 10 July 2018 - 02:27 PM.
#8 REDICE
REDICE
  • 44 posts
Posted 10 July 2018 - 11:19 PM
I'm in for a whole set of dampers as the Gaz ones are shot already (They haven't even done a couple thousand miles) . Just thought coil overs could be a good upgrade but was concerned about the extra loadings. Thanks for your replies I will stick to the rubber cones as they arent that old and just get a new set of dampers.
Mini Spares
