Coolant Liquid Overflow
9 replies to this topic
#1 Shaked
Shaked
  • 27 posts
Posted 12 July 2018 - 10:46 AM
hello
my 79 1275cc mini ,
just finished very extensive service,
unfortunately there is a massive oil leak,
the other thing which i am worry about
after few miles i stopped for gas
a burst of coolent fluid got out (it seems to be from the overflow pipe )
what could have caused this kind of problem ?
thank you
#2 Midas Mk1
Midas Mk1
  • 5,644 posts
  • Local Club: S.U.N.M.C
Posted 12 July 2018 - 10:53 AM
How far full did you fill the rad? Above the fins or to the top of the tank? If its overfilled, expansion when parked after a run will push the excess out of the overflow, happend to me a few weeks ago after a hard drive.
#3 Shaked
Shaked
  • 27 posts
Posted 12 July 2018 - 11:22 AM
fill rad about 1/2" below the ring where the cap seals
as i dont have any expansion tank .
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 12 July 2018 - 11:43 AM
Check the level again and it should be probably 1/2 an inch over the top of the gills as a minimum
if its less than that you may have a problem.
but It could just be purging air out of the system as it all settles down
top it up again (maybe a little less than before) and keep an eye on the engine temp and coolant level.
It may also be a rad cap issue...too short or weak
#5 Shaked
Shaked
  • 27 posts
Posted 12 July 2018 - 12:47 PM
Will do
#6 Shaked
Shaked
  • 27 posts
Posted 17 July 2018 - 05:27 AM
Sorry for late response
It’s seems to be about 1/2” under the lower ring
#7 andyapanel
andyapanel
  • 564 posts
Posted 17 July 2018 - 07:30 AM
Happened to me yesterday.
Always carry water to top up, just in case.
#8 Shaked
Shaked
  • 27 posts
Posted 25 July 2018 - 08:21 AM
hi guys
i noticed a new leak from the temperature transmitter
change for new one but still a very small leak
can i wrap it with any sealant ?
#9 andyapanel
andyapanel
  • 564 posts
Posted 25 July 2018 - 11:38 AM
PTFE tape
#10 andyapanel
andyapanel
  • 564 posts
Posted 26 July 2018 - 11:50 AM
I found out my problem was a split in the bypass hose. This is rather annoying as it was a Minispares black Kevlar one that was only 3 years and 4000 miles old.
