Edited by GoochieC123, 14 July 2018 - 12:32 PM.
Steering Wheel Fittings
Posted 14 July 2018 - 12:31 PM
Posted 14 July 2018 - 01:06 PM
No they are all the same from 1959 to at least 1992
Make sure you don't go too small I consider less than 12 inch diameter to be dangerous
Posted 14 July 2018 - 01:32 PM
as above all the same till that Air Bags came in IIRC
Posted 14 July 2018 - 03:01 PM
Posted 14 July 2018 - 05:26 PM
Aftermarket steering wheels usually have a removable centre boss which you can change to fit different vehicles, is you wheel like this?
Posted 14 July 2018 - 05:45 PM
https://www.picclick...man-mk1-mk2.jpg it's this one
Does it have a boss bolted to it? It looks just like one I had on an Austin Healey Sprite a few years back before I changed it to a Mota-Lita.
Posted 14 July 2018 - 05:58 PM
As Homersimpson has said, you can usually swap out the Boss in these types of wheels, but ideally, you need to identify the brand and in some instances, the type of wheel in order to obtain the correct Boss kit.
Posted 14 July 2018 - 11:13 PM
Posted 15 July 2018 - 03:43 PM
