Hot Wiper Motor
Posted 15 July 2018 - 05:08 PM
After I had got it running (it played up)I noticed that the body of the wiper motor was getting hot to touch. (The wipers were not in use)
What I am after is some pointers to what could be wrong before I pull it apart.
Posted 15 July 2018 - 06:02 PM
The motor has a permanent feed (if the ignition's on) which is interrupted by the park switch on the motor. As well as isolating that supply the park switch also earths the +ve side of the motor windings it stops immediately and doesn't run on past the park switch.
I can see a couple of possibilities:
The wiper mechanism has seized so the motor stalls before it operates the park switch - do the wipers run when switched on?
The park switch has worn down so it no longer fully isolates the supply, or it's shorting to earth - pull the park switch from the motor & operate it manually to experiment.
Posted 15 July 2018 - 06:27 PM
Posted 15 July 2018 - 10:00 PM
Does sound like an issue with the Parking Switch
