Fuel Cap Leak
2 replies to this topic
#1 JCmini
JCmini
  • 146 posts
Posted 16 July 2018 - 02:58 PM
Hello.
Just a quick one, every time I fill up i notice when I get home that fuel has leaked from the opening/cap and down the body work.
Is this normal (as in poor seal) or am I missing or can I buy something to stop it.
thanks
#2 unburntfuelinthemorning
  • 1,915 posts
Posted 16 July 2018 - 03:24 PM
Mine leaks when going round corners if I fill the tank too much but it's a van and has a vented cap as there is no separate breather.  I think the saloon caps (apart from early ones) should be non-vented as they have a separate fuel tank breather.  Injection cars should have non-vented caps.  So either you have a vented cap and are overfilling and/or the fuel cap seal isn't sealing.  You can buy replacement seals or the correct type of cap if the wrong type is fitted.
#3 buznout
buznout
  • Just Joined
  • 59 posts
Posted 02 August 2018 - 06:46 AM
Have the same issue with my SPi. Have the non-vented cap ad have tried a few and there is still gas build up that ends up leaking onto the body. I rarely put more than half a tank in so it isnt slosh!
