Dual Oil/water Gauge
Posted 16 July 2018 - 03:09 PM
I have encountered a problem. The bulb on the temperature sensor is too long and is catching of the inside of the head, preventing me from tightening the securing nut. The sensor is catching on the casting for the head bolts that is not fitted on my engine.
Anyone know a way around this, or an alternative to the Smiths dual gauge with the mechanical water temp sensor?
Posted 16 July 2018 - 03:46 PM
Have you used an adapter? I had to buy mine separately to the gauge.
http://www.minispare...30.aspx|Back to
Posted 16 July 2018 - 04:36 PM
You are correct, I just tried to screw the sensor into the head, this spacer makes sense.
Posted 16 July 2018 - 04:44 PM
Has anyone converted a dual gauge from capillary to electric water temp?
Posted 16 July 2018 - 04:58 PM
Maybe they have. Just go with the capillary tube - not as easy to fit but very accurate.
Posted 16 July 2018 - 05:58 PM
Perhaps the other question I should have asked is
why on earth would you if you can find a dual one electric for both use that as the capillary ones are more accurate and period ones are getting hard to get now.
Posted 17 July 2018 - 04:43 PM
Not that accurate, when I test the one I have with boiling water, it registers halfway between the N & the H, just where the bar the needle sweeps over goes solid. I know the boiling point is higher when under the pressure of the 15psi cap, but I did think the needle would have been a touch higher at 100C
Posted 17 July 2018 - 04:46 PM
Nicklouse they are still available for around £100.why on earth would you if you can find a dual one electric for both use that as the capillary ones are more accurate and period ones are getting hard to get now.Perhaps the other question I should have asked is
I bought a one off eBay with the capillary missing, thought it would not be too expensive to replace. When I checked with instrument manufacturers they reckoned the cost of repair was very similar to the cost of a new gauge!
I have since bought a working gauge via eBay for £50, but I feel the gauge under reads, the needle only goes halfway between N & H when the sensor is in boiling water 100C. I know the temp of the boiling point is higher when under pressure.
Edited by DUF2, 17 July 2018 - 07:10 PM.
Posted 17 July 2018 - 05:03 PM
Your engine should run +-88℃. So you know it should be a tad under the halfway mark.
Posted 17 July 2018 - 06:31 PM
Has anyone converted a dual gauge from capillary to electric water temp?why on earth would you if you can find a dual one electric for both use that as the capillary ones are more accurate and period ones are getting hard to get now.
Respectfully Nick, I don't think any of us need to read down to +/- 1 degree with them, all we really need is repeatability of the gauge and in this aspect, I've found them every bit as good as capillary gauges.
The elect gauges well show what's 'normal' and what's not.
Posted 17 July 2018 - 07:08 PM
Temperature is not higher under pressure, but the boiling point is. The higher the pressure the higher the boiling point, so you can have an engine running at say 110C without the water boiling due to the boiling point being higher due to the pressure of the pressure cap.Temp isnt higher under pressure.
The pressure comes from the expansion of the water as it becomes heated.
Water expands by 23% when it is heated from around 50F to 180F or thereabouts! Can't remember the exact figures it is a long time ago that I was at college studying as an apprentice heating engineer!!!
Posted 18 July 2018 - 12:04 AM
Ofcourse. Again, why I said temp isnt higher. See youve edited your mistake.
Posted 18 July 2018 - 11:32 AM
Is it the right sensor for the gauge?
Brand new capillary type gauges are only about £110-120 ..
Posted 18 July 2018 - 12:05 PM
I cannot find one online. Anyone know where I can get one
Posted 18 July 2018 - 12:09 PM
Hate to. Hijack this thread however I have the smiths dual gauge and now the temp gauge is not Working. I suspect the capillary line to be faulty.
you cant, the whole unit needs sending away for recharging and sealing.
