Dual Oil/water Gauge
#16
Posted 18 July 2018 - 12:42 PM
#17
Posted 18 July 2018 - 12:45 PM
Thanks for the reply. The unit is only a couple months old and the cap tube does unscrew from the gauge.. Why would. They need the gauge as well?
what make is it? only going on the ones I have used and seen where they don't unscrew.
#18
Posted 18 July 2018 - 12:47 PM
Come. To think about it. I actually can't recall if I screwed the end into the gauge or not.
#19
Posted 18 July 2018 - 02:50 PM
Not a capillary temp gauge .. they are sealed .. but if dual the oil pressure is a separate hose.
30 days? That's a bit short for a warranty .. who did you purchase it from?
#20
Posted 18 July 2018 - 03:05 PM
#21
Posted 05 August 2018 - 12:44 PM
No luck with a replacement. ended up buying a new one.... so far so good
#22
Posted 06 August 2018 - 05:12 PM
Have you used an adapter? I had to buy mine separately to the gauge.
http://www.minispare...30.aspx|Back to
Got the adaptor, just the job, will use the mechanical dual gauge now, leaving a spare hole in the dash for a 50mm tacho.
