Clutch Release Bearing......
Posted 16 July 2018 - 05:01 PM
Had some time spent on the Mini today and am wondering if the clutch release bearing is a bit dodgy.
The clutch seems to be a bit rough sometimes at engaging,by that I mean it suddenly bites,but sometimes it is smooth like a clutch should be.
It can also be hard to engage gear sometimes,especially 1st and 2nd but if I go from 3rd it will go into gear better.
I have noticed a clunk when you release the clutch pedal and a bit of rough sounding noise which disappears when you press the clutch in again.
I am wondering if the release bearing is going to give up at some point.
Thanks for any help folks.
Posted 16 July 2018 - 06:00 PM
which clutch system?
yes it could be.
Posted 16 July 2018 - 06:39 PM
Posted 16 July 2018 - 06:45 PM
Well worth checking and making sure everything is okay.
As said above which system is it? Pre verto or verto?
Posted 16 July 2018 - 08:11 PM
yes it could be.
Sorry,yeah,it's a verto,the cars an'89 but the engine is a '90/'91 A+ 1275.
Thanks guys.
Posted 16 July 2018 - 08:13 PM
Sudden biting of the clutch can be the friction plate ‘sticking’ to the flywheel or pressure plate.
What causes the plate to stick?
Ta.
Posted 17 July 2018 - 11:30 PM
It can be rust, dust and oil, on the lining / flywheel / backplate
it can also be the spinner plate sticking and binding on the primary gear, as it slides (or not) on the splines
Posted 17 July 2018 - 11:58 PM
I have seen the friction plate sticking on the primary gear before!
Posted 18 July 2018 - 07:35 AM
So,me thinks,take the cover plate off,check components and replace release bearing while I'm in there,right?
Posted 18 July 2018 - 08:00 AM
So,me thinks,take the cover plate off,check components and replace release bearing while I'm in there,right?It can be rust, dust and oil, on the lining / flywheel / backplate
Personally fit the complete clutch kit, and primary gear seal
Posted 18 July 2018 - 05:58 PM
Cover off, flywheel off, check primary gear end-float then primary gear off
Strip the clutch and check everything, clean every single thing. Best thing is clutch and brake cleaner.
Make sure there is plenty of meat on the spinner plate and that it moves nicely on the primary gear splines.
Primary gear should be spotless, check inside it too, they can bind up on the crank tail.
Fit the new trust bearing
Reassemble and refit the whole issue, should be sorted, and I hope it is.
Posted 18 July 2018 - 09:19 PM
Thanks for this,best get a flywheel puller ordered then!
And have a good read of the Haynes manual.
Posted 18 July 2018 - 09:35 PM
It does sound a bit drastic but its probably the best way,
Its one of those where there is probably very little wrong and you strip it find nothing, clean it all and it works perfectly afterwards.
It could also be the master or slave cylinder but points more towards the clutch itself
