My Fiberglass Mini Build
Posted 16 July 2018 - 09:56 PM
Posted 16 July 2018 - 09:58 PM
Looking forward to it, I doubt I need to tell you but fiberglass is nasty stuff so always make sure you're in a ventilated room with goggles and a mask if you're doing work on the shell!
Posted 16 July 2018 - 10:07 PM
Posted 16 July 2018 - 10:09 PM
Thanks I'll have both doors of the container open and will pick up some masks and goggles
Posted 17 July 2018 - 08:20 PM
So the new rear subframe turned up in the post with a few other bits: AF sockets 1/4" and 3/8 drive, paint bushes, fiberglass cloth,under seal, hardener and resin.
IMG_7582.JPG 63.66K 3 downloads
I also picked some fibreglass mat 300 and 450 weight from a local store and a metal roller (don't have pictures)
So I headed out tonight and tried my hand a fiberglassing the first pease that had been cut out back in.
IMG_7594.JPG 57.47K 3 downloads
Edited by Mini_Mad_Manx_Man, 17 July 2018 - 09:37 PM.
Posted 17 July 2018 - 08:35 PM
Do you know who made the shell?
And is that a standard mini size? As in not a sprint?
Posted 17 July 2018 - 08:50 PM
Hi I was told it was an FRA shell when I bought it, but to be honest I wouldn't know enough but each shell to tell them apart. I do however know it's a full size mini shell and not a Sprint.
Posted 17 July 2018 - 09:10 PM
i hope you have put some spacers between the upper and lower tower surfaces before glassing the front parts on.
Posted 17 July 2018 - 09:40 PM
I have'd started at the front yet. Starting at the back, what do you mean tho so I can take note for when I do start the front?
Posted 17 July 2018 - 09:52 PM
ok no pics at the moment. but on the steel cars there is a load spreader between those surfaces to stop/reduce the compression caused by the bolts. even though the bolts are shouldered the two surfaces are still supported. some think wall tube or machined down alloy bar would do.
Posted 17 July 2018 - 09:59 PM
ok found pics.
these should help
crossend.jpg 81.34K 0 downloads
cross-member-end.jpg 23.59K 0 downloads
Posted 17 July 2018 - 10:18 PM
Ok I see what you mean. I did have an idea for this, I was gonna get box section that fits snug in the area on it's side and then drill the holes for the tower bolts to go throw it. Didn't even think of tube upright, would mean I wouldn't have to drill holes.
Even with the end peaces back on you can still gain plenty of access from inside the car on this shell where the bulk head would be in the way on steel shells.
Posted 19 July 2018 - 09:50 PM
So today my rear subframe mounting and bush kit turned up from minispares.com but I'm a while off getting that fitted yet.
IMG_7604.JPG 48.69K 5 downloads
And I also went out to started getting the next and biggest piece that had been cut out back in place, will finish off and put final piece back in tomorrow night.
IMG_7600.JPG 66K 4 downloads
Posted 21 July 2018 - 11:06 PM
Last night I went out and fiberglassed the top of the final piece into place. Going to get the mini tipped onto it's side in the next week and do the full underside in one hit, just need to wait for more resin to show up.
Image-1 (1).jpg 72.09K 0 downloads
Also got the radios arms stripped and ready to be cleaned up and painted.
Image-1.jpg 106.63K 0 downloads
Posted 23 July 2018 - 09:15 PM
Not a lot done tonight with not being able to get to the container this week. But I have convinced the girl friend to let me bring some bits home to work on at the table/ in the garden. So tonight I cut the subframe mounts off the old subframe and painstakingly removed old bushes. Then gave them a clean up with a wire wheel on a grinder and a lick of paint.
IMG_7611.JPG 47.54K 2 downloads
