Does anyone know the reason why there are 2 holes on the water pump shaft and should water come out?
Water Pump.
aherrerags
, Jul 16 2018 10:04 PM
4 replies to this topic
Posted 16 July 2018 - 10:04 PM
Posted 16 July 2018 - 10:08 PM
I know of one hole in the body of the water pump which lets water out that has got past the shaft seal. If it's leaking here you need a new pump.
Posted 16 July 2018 - 10:17 PM
Is there no way to fix this? I thought it could just be a releive valve
Posted 16 July 2018 - 11:03 PM
new pump.
Posted 17 July 2018 - 06:16 AM
If you are getting any water out of those holes, then these days, as Nick has said, the only fix is a new pump.
One of these is a 'tell tale' to let you know that the pump seal has gone.
