Yeah it only has the one fuel filter on the rear subframe. All fuel lines/pipes have been checked
Mpi Resistance Feeling
Classicmini63
, Jul 17 2018 07:54 AM
16 replies to this topic
#16
Posted 20 July 2018 - 08:54 AM
#17
Posted 20 July 2018 - 09:59 AM
The fuel pump blowing standard fuse but running "OK" on higher fuse means either a faulty pump ( low fuel pressure) or pump having to work too hard ( restricted fuel flow). Is the fuel filter your changing the standard one on the subframe or an additional one in the engine bay? Can anybody confirm if the MPi tank pickup has a gause filter like early tanks? Check pipes and hoses for kinks.
Hi,
I think there's a gauze filter sock on the bottom of the in-tank pump.
