Mini Van Steering Wheel To Storks
Best Answer Homersimpson , 17 July 2018 - 09:04 PM
thanks, if you look at the wheel and where the plastic part is you marked, they dont meet. I cant get the STALKS and the wheel to mate up. There is maybe 2-3mm gap
Is the column outer correctly aligned in the clamp? You can move this up and down a bit and may just have been fitted too low.
Go to the full post
5 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,133 posts
Posted 17 July 2018 - 05:33 PM
mini van is 1981, its got the indicator storks with the wipers on the left, and got the factor steering wheel on it. I took the storks off to fix them, and when ive put them back, the 2 pins on the wheel dont reach the colour on the storks to cancel the indicators. Ive tried moving them up but they dont sit right. Are these the wrong storks for the van or is there some thing missing ?
I dont know if they cancelled before.
#2 wzd345
wzd345
  • 76 posts
  • Local Club: Miniresource
Posted 17 July 2018 - 06:10 PM
Stalks, no storks!!!!!!
#3 Spider
  • 13,929 posts
Posted 17 July 2018 - 06:27 PM
The collar on the Indicator switch is best aligned to the position as shown below, there's a 'marker' on it for when the wheels are in the straight ahead position. I've put some blue felt tip on it to make it a bit easier to see
#4 Avtovaz
Avtovaz
  • 1,133 posts
Posted 17 July 2018 - 08:13 PM
#5 Homersimpson
Homersimpson
  • 803 posts
Posted 17 July 2018 - 09:04 PM   Best Answer
#6 Avtovaz
Avtovaz
  • 1,133 posts
Posted 17 July 2018 - 09:38 PM
could well be! never thought of that and that would explain everything! thankyou ! will report back
