If its for the road don't use SC drop gears they are horrendously noisy, you need a helmet or ear-plugs or both !!
MPi type drop gears are said to be the best.
The flywheel housing on Turbo engines has a bigger pilot bearing on the end of the 1st motion gear/shaft if you can find a genuine housing its a good upgrade, if not a standard housing can be machined out for the bigger bearing. (same casting)
Only use RHP bearings in the gearbox too, anything else is not worth fitting.
I can supply pistons more than upto the job considerably cheaper than Omegas
You will also need a Turbo oil pump,Turbo type fuel pressure regulator, a high pressure fuel pump, an injection fuel tank (or one with 2 outlets)
Standard Turbo heads have an exhaust valve which is sodium filled to help cool the valve (8mm stem)
There are a lot of oil related things that can be done to reduce oil drag and heat in the block..most involving drills, files and sweat
Head wise Turbo Phil (on here) is the man. The use / engine CC'c / head / valve sizes/ cam / timing / compression should be considered as one.
Camshaft is a big consideration, an MG metro type or there abouts is really good for the road
Diff ratio is another to consider the turbo had a 3.2 which I would stick to for the road
The clutch also need to be at least as good as a standard Turbo depending on what you go for.
Bear in mind at the moment nobody can get uprated pre verto diaphragms
A huge amount depends on if you can do things yourself, your budget and what you want to achieve.
Give me a ring or PM if you want a chat, I can do better prices than MS Smfrd or Msprt
I can produce you a complete engine / short engine / Kit / gearbox / parts or what ever you want to do
Whatever route you take the engine package has to work in synergy and be considered as a whole (as you probably know)
You only need one week link between your right foot and the road and a Turbo will exploit it more than a NA engine. Be careful as there are so many poor components out there.
