Running Hot.
Posted 18 July 2018 - 11:02 AM
Thanks in advance!
Posted 18 July 2018 - 12:05 PM
Welcome to the forum
Posted 18 July 2018 - 12:18 PM
Hi,
Welcome aboard.
Is everything new, radiator, pump, stat?
Is the timing set correctly?
Have you put the fan on the right way round?
Posted 18 July 2018 - 12:39 PM
and id the gauge wired correctly and the sensor correct for said gauge.
is it actually getting hot?
Posted 18 July 2018 - 01:30 PM
On a side note now living in the uk and planning on bringing my mini over next year.. should be one of two GTS in the uk!
Posted 18 July 2018 - 05:00 PM
A freshly rebored engine will tend to run a bit hotter until the rings bed in.
Also worth checking that there is not excessive friction. For example if ring grooves in the pistons are not deep enough it can be assembled and have correct ring gap, but when it warms up the rings get tight. Shouldn't happen if pistons and rings are correct, but not unknown.
Posted 18 July 2018 - 05:49 PM
I am guessing its pretty hot in SA do you know what rad it is, and are the gills clean?
Are you running a thermostat ?
Posted 18 July 2018 - 06:15 PM
Posted 18 July 2018 - 07:02 PM
Other than being bored out a long way, are there any other mods to the engine, intake or exhaust system?
Posted 18 July 2018 - 07:10 PM
Posted 18 July 2018 - 07:47 PM
To my way of thinking you need better rad and a 74dgree stat or a blanking sleeve
When I do any big cc engines i cut the water jacket at the back side of the water pump
and various oil gallery pump work which helps keep the temps down
Posted 18 July 2018 - 07:55 PM
I assume to check for play/movement on the rings I’d need to strip the engine completely again??
Does the engine seem at all stiff? You could do a basic check by taking the cylinder head off and then put the piston to top dead centre. There should be about 15-20 thou gap between piston and bore, and you should be able to move top of piston fore/aft until the top land of the piston almost touches the bore. Also if head is off check bores for any signs of unexpected polishing which could indicate the pistons/rings are nipping up.
Posted 18 July 2018 - 08:18 PM
Posted 18 July 2018 - 08:20 PM
