Front Subframe Top Mounting Bolts
7 replies to this topic
#1 Matt Zane
Matt Zane
  • 215 posts
Posted 18 July 2018 - 03:18 PM
Good Afternoon Gentlemen,
I hope this message finds you all well. I have a quick question.
I have a 1974 round-nose car, I'm slowly working my way from back to front sorting out perished rubbers etc.
Amongst other things, I am going to be installing a new set of front cones and high-lows, so I've been looking at the job and trying to figure out what tools I'm going to have to buy.
I know I'll need a cone spring compressor, and because I don't know whether the car has had the front springs changed over the course of it's life, I'm going to have to buy the double ended tool.
The second tool that has cropped up in my research is the 34mm Socket for removing the sub-frame top mounting bolts.
This is where I've run into a bit of an issue - as I don't seem to have any sub-frame top bolts - I have some holes, which I had assumed were for access to the top of the cone spring, and were originally blanked off with a rubber grommets.
Have the how-to's I've read been carried out on a later car, or am I missing something potentially vital? The
If so is a pair of the standard items from Mini Spares going to do the job?  And what do they do they bolt into?
I'm sorry if this is a bit of daft question, but I can't seem to find the answer, or I'm asking the question wrong.
Thanks in advance,
Matt
#2 imack
imack
  • 1,873 posts
Posted 18 July 2018 - 03:48 PM
A '74 car won't have the big tower bolts, instead it has the mk1 style 'twin bolt' subframe that is bolted solidly to the vehicles body.
You should have a rubber grommet in the large hole in the cross member and a bolt either side of that hole thats secured with a lock tab.
#3 wzd345
wzd345
  • 76 posts
  • Local Club: Miniresource
Posted 18 July 2018 - 04:48 PM
If you don't have the correct 4 top securing bolts for the subframe, they can be replaced with cylinder head studs (from memory, the long ones) and suitable nuts/washers.  They will also greatly facilitate easy fitting of the subframe into place.
#4 Rorf
Rorf
  • 859 posts
Posted 18 July 2018 - 04:53 PM
Not possible to take a photo of your situation for us to better understand what is going on there? As stated there should be two bolts or nuts either side of the big hole.
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,899 posts
  • Name: Neil
Posted 18 July 2018 - 06:18 PM
This is the full kit for a pre 76 subframe
http://www.minispare...90.aspx|Back to
#6 Swift_General
Swift_General
  • 870 posts
Posted 18 July 2018 - 08:09 PM
Sounds like you may just be missing the rubber grommet that covers the hole that you would used the spring compressor with and perhaps you've been looking for the large tower bolts which you shouldn't have on a '74 model and missed the 2 smaller bolts either side? As mentioned pics would help.
#7 Matt Zane
Matt Zane
  • 215 posts
Posted 18 July 2018 - 09:07 PM
Lol! I suspect that is probably the case. I'll have a check tomorrow evening, and let you know.
Thanks,
Matt
#8 sonikk4
sonikk4
  • 15,899 posts
  • Name: Neil
Posted 19 July 2018 - 12:33 PM
73bd62d336c912ea3585880cc2274d6f1ff5b019
That's how it should look.
