Boiling Mpi (In The Alps)
5 replies to this topic
#1 gronkjor
gronkjor
  • 250 posts
Posted 18 July 2018 - 05:29 PM
Hi ladies and gents
I am currently on a bit of a roadtrip from Denmark to France and Switzerland. The first week everything has been going well, and I have really been enjoying the drive and the scenery.
Until today.. 3 hour motorway drive in France followed by 15 minutes steep mountain drive in Switzerland which made the car start to boil. Leaked a bit of water too. After 9 years of ownership it is the first time the car has been boiling. The fan kicks when its warm, so I don't think that is the issue. Should be said it is about 30 degrees hot outside.
Question is whether something is wrong or whether the hot weather combined with a long drive and a long mountain drive simply is too much for the cooling system to handle.
Cheers in advance from a slightly worried MPI owner in a Swiss cabin.  :shades:
#2 tmsmini
tmsmini
  • 709 posts
  • Local Club: MOASF
Posted 18 July 2018 - 05:41 PM
Could be a failed expansion tank cap. Not uncommon after nine years, it if has not been replaced.
Terry
#3 gronkjor
gronkjor
  • 250 posts
Posted 18 July 2018 - 06:10 PM
Thanks for replying. I changed that two years ago, but I suppose it could be failing again  :geek:
#4 Midas Mk1
Midas Mk1
  • 5,643 posts
  • Local Club: S.U.N.M.C
Posted 18 July 2018 - 06:16 PM
I believe the r53 cooper s cap maybe the same thread if that's easier to find where you are.
#5 Bat
Bat
  • 903 posts
Posted 18 July 2018 - 06:19 PM
Hi,
Probably a cooling system flush and some fresh coolant will see you back to normal.
Cheers :proud:
#6 tmsmini
tmsmini
  • 709 posts
  • Local Club: MOASF
Posted 18 July 2018 - 08:45 PM
I was wondering if the R53 cap was the same pressure relief. It looks identical and seems to fit.
