Intercooler To Replace Grille
Posted 19 July 2018 - 10:47 AM
Would this be a good idea and what does it look like?
Cheers for any info!
Will
Posted 19 July 2018 - 12:08 PM
Will,
I've seen it done before, its the best place to get fresh, cool air. However, you'll have to consider it will stick right out the front of the car!
Don't rule out using a charge cooler. You could put a simple set up on a side mounted radiator engine and have the cooling radiator in between the grill and the front panel (22mm core). I'm going this route as the MPi engine bay has little/no room for an effective intercooler set up, I've had to go custom charge cooler radiator.
Posted 19 July 2018 - 12:40 PM
Will,
Thank you, I'll have a look into that!
Posted 19 July 2018 - 01:21 PM
Posted 19 July 2018 - 03:07 PM
Hi,
You can fit one under the front bumper, if you're creative!
IMG_0074.jpg 86.21K 2 downloads
There's mini city e turbo on here with a 998 turbo with the intercooler out front.
Posted 19 July 2018 - 03:37 PM
Hi,
Looks good! I'm going to have to start learning how to weld though!
Posted 19 July 2018 - 04:03 PM
Hi,
Keep your hair cut short too, it makes it harder to pull out!!!
Posted 17 November 2018 - 06:13 AM
Had the same thought. Here's one kind of along those lines (not mine).
Intercooler.jpg 65.32K 3 downloads
