Mg Metro Valve Clearance
Posted 19 July 2018 - 03:44 PM
Thanks.
Posted 19 July 2018 - 04:23 PM
Edited by Dusky, 19 July 2018 - 04:23 PM.
Posted 19 July 2018 - 05:34 PM
Posted 19 July 2018 - 06:11 PM
0.012" is OK for all A-series engines unless very high ratio rockers are fitted (like over 1.5:1)
For a valve stem to expand by even half of that amount would mean the engine is seriously overheated.
The issues with changes to valve opening time is not relevant as it is very slight.
Posted 19 July 2018 - 06:32 PM
All factory engines, Including the MG Metro, had 0.012" recommended clearances.
Posted 19 July 2018 - 07:51 PM
Posted 20 July 2018 - 12:34 AM
According to the Haynes MG Metro manual ;
1982/3 inlet 13 exh 16
1985 on both 14
Compression is 10.5 :1
the Turbo is 9.4 : 1 compression with valves clearances 14/16 1982/3 and 13/15 '84 onwards
Both compressions are half a point higher than I thought, I will be checking next time I strip a std MG motor.
