With an aftermarket electronic ignition should you fit resistor type plugs?
If you dont I assume its only the radio thats affected?
Posted 20 July 2018 - 07:34 AM
Posted 20 July 2018 - 07:42 AM
most of the time the leads suppress any noise anyway. the ignition type has little bearing on anything. it is more dependent on the leads.
Posted 20 July 2018 - 07:45 AM
non resistor plugs will interfere with ECU's even with resistive leads,
I tried nonresistor plugs on my efi 7 port and it kept clobbering the ECU so it kept resetting.
Posted 20 July 2018 - 09:04 AM
Posted 20 July 2018 - 09:56 AM
Hi,
I've always ran R plugs. Not had anything standard in the last 3 decades so always 7s. NGK BPR7ES for me.
Posted 20 July 2018 - 10:54 AM
What cc's ?
What state of tune / spec ?
Posted 20 July 2018 - 11:36 AM
Posted 20 July 2018 - 02:25 PM
What cc's ?
Completely standard 998 but with the aftermarket electronic ignition
Think it has Bosch R6 at the mo.
Edited by Haynes, 20 July 2018 - 02:26 PM.
Posted 20 July 2018 - 05:42 PM
NGK BP6ES gapped at 0.035" will work fine for you
Posted 20 July 2018 - 09:03 PM
Electronic ignition and programmable ignition are two different things. It may be that electronic ignition does not require the R plugs since it is likely the coil has a condenser fitted and the electronics are very simple. If there is any sort of ECU that is using a variable reluctance crank position sensor, then the story is very different and R plugs are a must for reliable operation.
