What Paint Between Inner And Outer Sill?
2 replies to this topic
#1 Verderad
Verderad
  • 393 posts
Posted 20 July 2018 - 09:49 PM
Ive purchased replacement half floor assemblies with the outer sill attached from M Machine. Nice Fresh but bare metal!!
Before I fit them I intend to paint the cavity between inner and outer sill, however i'm drowning in research and cant decide where to start.
I plan to de-grease surfaces using thinners, should I then give it a rub over with with Scotch-Brite before applying primer?
Should I use an etch primer before applying a primer?
What type of primer should I use?  should I use a cellulose primer or is this porous?
Do I need to apply a top coat?
I was planning on using rattle cans for this, i do have access to one of those hobby sprayers if that opens up a wider range of paint to use.
finish is not important as it wont be seen.
 bought SAS Zinc primer to flash over welds etc before having the car painted but I don't think this is suitable for finishing bare metal.
Looking forward to the advise.
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 21 July 2018 - 06:59 AM
I used cold galvanising spray paint on mine, hopefully will last well.
#3 Compdoc
Compdoc
  • 609 posts
Posted 22 July 2018 - 04:18 PM
I rubbed down with scotch pads, gave the areas that will be welded a light coat of copper weld through primer. Then masked of these areas and gave it a light coat of Electrox (90% Zinc), then a heavy coat of epoxy primer. I used Jotun which is used on ships and oil rigs. I used a brush and mini roller so OK with an ordinary paint mask.
https://www.bilthamb...tments/electrox
https://www.ebay.co....lrs=spell_check
