Front Suspension Cone Removal, Seized To Trumpet
Best Answer Homersimpson , 21 July 2018 - 04:13 PM
I've seen people separate them with an air chisel inserted between the donut and trumpet, if you don't have one then just cut the trumpet.
Go to the full post
10 replies to this topic
#1 tino
tino
  • 781 posts
Posted 21 July 2018 - 02:10 PM
Hi All,
Slowly progressing with my very long project... got to replacing the Suspension Rubber and Cone's and the Front Passenger Side is Seized to the Trumpet. I've tried heating it up a few times but it's awkward as its in the front subframe still. Is there a way to remove it with it Seized?
I've removed the top arm to give me more space and got that off. The top of the cone where the thread for the compression tool to fit is filled with rust and has no usable thread left so, although the Top Arm is out luckily so I have some movement.
I'm guessing it's going to be cut the trumpet with a saw of some kind. I have a replacement so I don't particulary care about the trumpet.
Thanks for the advice!
tino
Edited by tino, 21 July 2018 - 02:13 PM.
#2 racingbob
racingbob
  • 3,061 posts
Posted 21 July 2018 - 02:18 PM
we had to saw my mates off a back one
#3 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 21 July 2018 - 02:38 PM
The only comment to add is that if you can't get at it with a saw then drill multiple holes in one area until it will snap when hit with a suitable piece of bar/chisel
#4 tino
tino
  • 781 posts
Posted 21 July 2018 - 02:40 PM
Thanks very much for your quick reply, assumed that would be the case.
#5 Homersimpson
Homersimpson
  • 803 posts
Posted 21 July 2018 - 04:13 PM   Best Answer
#6 Bat
Bat
  • 903 posts
Posted 21 July 2018 - 04:51 PM
Hi,
Hammer and chisel between the two. Try it with the cone compressed to give you something solid to hit against.
Cheers  :proud:
#7 tino
tino
  • 781 posts
Posted 21 July 2018 - 04:57 PM
Didn't think of this! Made light work of it :lol:
Hi,
Cheers  :proud:
The thread on the other side had rusted and there was nothing for the cone compressor to thread into. It only just held enough to get the top arm out.
#8 Thelowrider
Thelowrider
  • Just Joined
  • 90 posts
Posted 21 July 2018 - 04:58 PM
If it doesn’t come apart then the hammer isn’t big enough! :lol:
#9 Spider
  • 13,935 posts
Posted 21 July 2018 - 08:40 PM
Hi,
Cheers  :proud:
That's how I've done them, only, I found it easier to leave them in the subframe as then I had something to hold the rubber cone, but didn't compress them too much or it's too hard to get at.
#10 nicklouse
  • 17,945 posts
Posted 21 July 2018 - 09:46 PM
masonry chisel. work you way around it.
#11 tino
tino
  • 781 posts
Posted 21 July 2018 - 09:53 PM
Thanks everyone for their replies, it is much appreciated.
The Air Chisel worked in seconds and made light work of it.
The old cone is in a pretty bad shape.
