I'm currently gathering parts for a turbo 1293 engine, looking to boost at between 5 and 10psi. What crankshaft(s) would you recommend for the build? Preferably around £500. Cheers!
Will
Posted 26 July 2018 - 04:27 PM
Will
Posted 26 July 2018 - 04:48 PM
Posted 26 July 2018 - 07:36 PM
Standard will be more than fine. Mine's balanced & hardened but otherwise standard. 20 psi & 7,000rpm didn't seem to bother it.
Phil.
Posted 26 July 2018 - 07:44 PM
Phil.
Standard, balanced. Maybe wedged if you can afford it.
Thank you!
Posted 26 July 2018 - 10:29 PM
mine is standard 6581, the supposedly better one from the metro. Most be just use standard, a turbo motor doesnt need to work as hard as a NA engine to make power. You wont be spending long periods of time at high RPMs. And 5-10psi isnt that much boost compared to what some people run
