Various parts left over from job lots i've bought. All parts can be posted (P+P extra) or collected from Bromyard, Herefordshire.
Parts are as follows:
Exhaust/inlet manifold to suit 1 1/2" SU carb - £10
Exhaust/inlet manifold to suit 1 1/4" SU carb - £10
Radiator fan cowling, one-piece type - £15
Ignition weather shield cover - £15
Verto clutch complete assembly - £25
Pre A+ small bore type transfer gear housing - £20
Clutch covers - £15 each
8.4" brake calipers/drive flanges/shields - £25
Pre-verto clutch pressure plate, part no. 22A598 - £10
Thermostat housing & sandwich plate with mounting bolts - £20
Diff output shafts, CV pot joint type - £10 per pair
New Pre A+ idler gear bearings, bought from Minispares but never used, £10
New igniton points & condenser, fits post 1980 Ducellier distributors, Contact points part no. GCS119, Condenser part no. GCS2113.
Early A+ 1st motion shaft & Laygear, A series tooth profile with A+ size bearings, included is a early A+ mainshaft, uses the 18mm nose bearing but smaller pinion nut - £50
