Usb Port On The Rear Seat Board
Posted 29 July 2018 - 09:45 AM
Posted 29 July 2018 - 12:19 PM
I took a wire forward under the carpet and out to a separate 10a fuse in a second fusebox on the bulkhead.I use this rear cigarette lighter port for a powered coolbox on the back seat, also added a USB port under the passenger side of the parcel shelf for Satnav and charging etc
Posted 29 July 2018 - 09:25 PM
Hi,
I'd say the battery is just behind the seat, but if you've got standard cable connections it's going to to be difficult to connect up.
Go forward to the fuse box as discussed above, choose your wire colour for permanent supply or ignition controlled.
Posted 31 July 2018 - 06:46 PM
