Spi Fuel Filter
Posted 30 July 2018 - 09:19 AM
On removing the rear subframe to do the sills on my latest mini I noticed the fuel filter fitted under there.
This is my first experience with an injection mini so coming across quite a few different bits and pieces.
Is it common to do anything with this filter? I.e: move it, change it, update it etc.
Thanks.
Posted 30 July 2018 - 09:36 AM
Hi,
Just like any other filter, change it when the vehicle manufacturer recommends.
If it looks years old go straight to putting a new one on!
Posted 30 July 2018 - 10:15 AM
Change it, but you'll likely find that the in/out connecting nuts have rusted solid. I had to remove mine as I couldn't get them undone. I used some new fuel line to replace the metal existing pipework and plumbed in a generic fuel filter. I think it's a part from a Vauxhall Astra or Citroen Saxo, needs an external diameter of about 55mm & length of about 140mm for the spi bracket
https://www.buycarpa...premium/7172812
Posted 30 July 2018 - 03:39 PM
I've done the same conversion from hard line with threaded connections either side of the filter to hose with screw clip connections attached to a generic filter. Easy and no problems to date. Keep the filter mounting bracket and use a full length of hose from the tank to the filter via the grommet in the boot floor.
