Its more likely that the head is cracked rather than the block
As it had been over-heated the head should have been pressure tested, do you know if it was ?
It could also be a stuck thermostat which is a simple fix, was it renewed ?
Don't think the head is cracked as that was skimmed and I would be amazed if it wasn't checked over by both the mechanic and the skimmers... I believe it was pressure tested on the day by the AA and don't remember it being a big issue, maybe a small loss but that was most likely down to the warped head which was skimmed... As for the thermostat, think that is fine, fan comes on as it should. Will be sent to someone who knows what they're talking about!
