Oil Leaking
Posted 01 August 2018 - 06:48 PM
Posted 01 August 2018 - 06:58 PM
looking at the condition of the threads i dont think you have actually torqued the head correctly.
and yes it is a problem if it is actually leaking. and not oil collecting there after leaking from the rocker cover gasket.
Posted 01 August 2018 - 07:02 PM
Posted 01 August 2018 - 07:49 PM
Run engine through a complete heat cycle and allow to go cold. Individually back off each nut and retorque.
Posted 01 August 2018 - 07:54 PM
Posted 01 August 2018 - 08:33 PM
I doubt it would be Oil leaking there as there's no Oil around that part of the head / block.
Do as Graeme suggested ^. Run it with water and not coolant for a few heat cycles, then check it again. If all is OK, then swap over to coolant.
Posted 01 August 2018 - 08:58 PM
I doubt if there was a leak, it would leak that quickly. Just make sure its not running down from the rocker cover.
