Non ballast car 1976
New cap
New condensor
Tried different king/ht leads
Tried 1 other coil non ballast
Both coils 3.2ohms/12.35volts
Tested/Cleaned contact points (sparks with screwdriver)
Cleaned rotor arm
The carb I have completely stripped and checked over and is running an AAC needle.
Dash pot has correct oil
Plenty of compression on engine 60k on clocks
Spark plugs not new but cleaned with wire brush and got 12 spares to try
Checked ground strap
Getting lots of fuel.
Each spark plug has a spark but not a great spark in my opinion.
I've literally taken this out of a 1988 mini last Sunday so timing shouldn't be a problem theoretically. Pictures ar before I removed and now.
So has anyone got an idea of what the problem could be? Driving me up the wall
Thanks in advance!
