Quandry
Posted 04 August 2018 - 01:47 PM
Posted 04 August 2018 - 06:58 PM
Depends on whether you want to look like a 'boy racer' .I think your car looks great as it is. Nice 'period' look with an excellent paint finish.
Why spoil it by making it look like a 'maybe racing/rally car'?
However, it is your car to do with as you wish and to enjoy. The only thing I would do were it mine is to run chrome trim down each side on the lower flange and carry this over the wheel arch extensions. Now that always looks super.
Posted 04 August 2018 - 07:27 PM
Posted 04 August 2018 - 09:01 PM
White door squares would suit the "Monte" look that your Mini has already!
Posted 05 August 2018 - 11:05 AM
Posted 07 August 2018 - 09:10 AM
white stripes would finish it in my eyes
twopence worth added.
Posted 07 August 2018 - 12:15 PM
As said above I think squares are better for the rally look. Circles go better for the circuit racer look. Sticky fingers do them in OEW to match the roof, bright white would be too stark.
Posted 07 August 2018 - 04:10 PM
Personally I think the OP's car looks absolutely great as it is, with the possible addition of the chrome side trims along the lower seams and over the wheel arch extensions. Bonnet stripes might look good. If it is available, chrome door frame cappings would make it very '1960's Cooper-ish' and look great, although back then it was quite usual to remove those strips to save a bit of weight. The bumper over-riders were also normally removed, again to save weight.
To try to turn it into a 'boy racer' make-believe rally car would possibly spoil its real '1960's retro look' which it certainly has at present. But then, it's not my car. My 1964 'S' has painted-on white squares on the doors, but it is a 'real' international spec rally car which had done a lot of rallying and I painted the squares on because the plastic Fablon sheet would never go down flat without air-bubbles and it looked 'naff'.
Whatever you do, it looks like you have a very nice Mini.
Posted 07 August 2018 - 04:49 PM
If its muck,then nothing to worry over
But if that's rot starting under the arch,that would be where i'd start
Other than that,great looking car.Wouldn't change a thing.
Posted 08 August 2018 - 08:32 PM
As Cooperman says, don't change it - it looks great as it is
The way it is I would be proud to call that mine
Posted 08 August 2018 - 08:55 PM
I've had the trims sat in the garage for over two years - still summoning the nerve to fit it!
Drop in in a bucket of hot water prior to fitting - softens it up and reduces the risk of kinking
Posted 08 August 2018 - 10:10 PM
Better than using hot water is using a hair dryer, or a heat gun on a low setting.
Posted 09 August 2018 - 08:20 AM
Posted 09 August 2018 - 09:26 PM
I know what you mean about the boy racer look and I would have agreed with you wholeheartedly before I saw the Café Racer Mini video posted on TMF recently. Now I'm thinking that having never been a boy racer, now that I approach my 60's perhaps it's time! I don't think anyone would think that car was an actual racing car - it's fairly obvious it's tongue in cheek but it gives it a distinctive look also captured by the current crop of café racer motorcycles being produced by mainstream and custom manufacturers. As the roundels are easily removable I may try the look and put some comparison pics up for judgement.
