How Much Oil To Rockers
Posted 05 August 2018 - 02:09 PM
Posted 05 August 2018 - 02:18 PM
There's normally a reasonable amount of oil there. If it seems excessive the rocker shaft could be worn but they don't cost much. Sorry not much help - someone else'll provide a better answer soon...
Posted 05 August 2018 - 04:00 PM
not loads, a film and splashing about is normal.
the oil feed for the rockers comes via the cam bearing nearest the rad, nd the cam and bearing are grooved in a way that gives a squirt of oil each rotation. it is possible to put the cam bearing in wrong so that the rockers are fed all the time and apparently this can fill the rockerbox with oil whoch causes an issue with oil getting down the guides.
Posted 05 August 2018 - 06:10 PM
the rocker post do need to be put in the correct place as one caries the oil to the shaft. which is why there is the taper nosed grub screw that locates the shaft in the correct place and has the lock plate to hold it in place.
Posted 07 August 2018 - 07:55 PM
I very much doubt that the drain holes between the cam followers could not cope with the relatively low pressure oil that flows through the narrow oil galleries to the rocker shaft.
Posted 08 August 2018 - 07:38 AM
Well Its not somthuiig I have experienced personally as I always fit my cam bearings correctly... But Ive seen enough reports of it over the years to belive it.
https://www.minimani...r_top_of_engine
https://www.minimani...bearing_removal
http://www.ausmini.c...mshaft&start=15
http://www.ausmini.c...ng cam camshaft
