Some S head bolts were stamped 300
Anyone know when or why ?
Posted 07 August 2018 - 08:46 AM
Posted 07 August 2018 - 09:00 AM
IIRC there are other number as well. and blank ones.
I have three that are different.
Posted 07 August 2018 - 09:02 AM
Be interested to know the other number only seen blank and 300
Posted 07 August 2018 - 09:06 AM
I will pop into the garage over lunch and report back.
the ones stamped 300 are from Greek cars.
Posted 07 August 2018 - 10:11 AM
for real?
Posted 07 August 2018 - 10:28 AM
for real?
I'm sure he's pulling yr leg !!
The only ones I've seen had 300 stamped in to them, but that's not at all to say there was other stampings. As far as I am aware, there was only ever one P/N (AEG248) for these so I doubt there'd been a change at any point.
Posted 07 August 2018 - 10:33 AM
just been to have a look and it is amazing what the light can do.
the one with rings on I did not think had 300 on it but it does.
IMG_1786.JPG 82.18K 2 downloads IMG_1787.JPG 37.86K 1 downloads
Posted 07 August 2018 - 12:21 PM
LOL,
yeah sorry that was an obscure Battle of Thermopylae gag..
Posted 07 August 2018 - 03:34 PM
no something to do with the 300 spartans
for real?
Posted 07 August 2018 - 08:10 PM
Cheers guys so it looks like they were all 300's and like Nicks some had the circle machining.
I think the 300 comes from inch pounds torque....about 25 Lb Ft and exactly what it should be torqued too...even in Greece LOL
Posted 25 August 2018 - 08:09 AM
Your lucky day Retroman.
While researching for another project, I came across this
Confirming your guess
Posted 25 August 2018 - 08:41 AM
Wow, Moke; if you can come up with that sort of info, I'm sure you must be able to find the the grade of steel used for the cranks in BMC's 948 diesel engines that were fitted to the Morris Minor Vans, used by the GPO.
Posted 25 August 2018 - 08:55 AM
,,,,, the grade of steel used for the cranks in BMC's 948 diesel engines that were fitted to the Morris Minor Vans, used by the GPO.
Cheers for that. I may have that somewhere,,,,,,, I didn't know those engines were fitted to any road vehicle, but there you go ! The only application I was aware of for them was in a Mini Tractor
Posted 25 August 2018 - 09:15 AM
Oh yes, they were in the vans before they showed up in the tractor; and they found their way into Canal Barges.
Never heard of one in an aeroplane, but I have seen the engine from a Reliant Robin in one, when a pilot dropped in at the aero club !
