Modern electrics make a joke of being 'green' they tend to be the downfall of cars and why you need a new one, really green.
The Pug 205 was a good car with really poor french wiring, which must have caused 1000's to be scrapped.
Most of the electronic crap you don't need anyway...I can't wait for a self sensing heated steering wheel hahhaha
I wouldn't care if the bloody stuff actually did what it was supposed to do
Like soft touch switches, and all the self sensing crap that I can react faster than.
Cats are another green con, guess they tick more EU green boxes like the scrapage scheme, disposing of perfectly good classic cars for no reason other than selling more new ******* on the premise of being greener.
Gullible is not in the dictionary
Electronic "improvements" on the newer Focus include:
reversing sensors which are really loud, cannot be switched off and either overreact or miss things;
auto dipping mirror which didn't always dip when needed with no manual overide (Mercedes one worked very well);
traction controls which cuts power at the slightest tyre scrabble in the dry just as you've pulled out and need maximum power - highly dangerous (again Mercedes one worked very well);
automatic headlight activation which thankfully you don't have to use; rain sensing intermittent wipe which isn't that good (Merecedes one much better);
turning heater to cold automatically puts air-con on - if I want it on I'll switch it on;
a completely distracting and hard to use radio thing which dazzles at night unless you fiddle with the settings which are buried deep in the rubbish menu - a dim/bright switch would have sufficed;
and an interior light between the visors which dazzles you when you switch the ignition off at night and it comes on without being asked - at least this can be switched off.
The Mercedes did the above much better despite being ten years older but it prefered instead to take out the abs/traction control/emergency braking system all together and then lock the transmission into second gear at the slightest sniff of a problem - managed to fix it a few times - one was a broken abs sensing ring on the driveshaft so something quite simple - but the third time it then got stuck in neutral and the starter motor wouldn't operate so I scrapped it and bought a Mini.
