And also, where can I find a replacement Union, as I'm re-doing all the brake lines?
Any help gratefully received
Clive
Edited by 533clive, 07 August 2018 - 05:48 PM.
Posted 07 August 2018 - 05:45 PM
Posted 07 August 2018 - 06:22 PM
the standard is not 11mm. 3/8unf
and yes there is one metric thread so you fit the pipes correctly. M10
and most Auto suppliers have them. Minispares for instance.
Edited by nicklouse, 07 August 2018 - 06:23 PM.
Posted 07 August 2018 - 06:25 PM
I think they did the different sizes so that the lines can't be mixed up, which I think you'd be going pretty hard to do.
The Tube Nuts shouldn't be too hard to find at all, CBS, Somerfords, Mini Spares and even your local Brake Shop should be able to supply them.
Be aware that these Tubes Nuts for the Yellow Tag Master Cylinder M10 x 1.0 and M12 x 1.0 respectively. Most other fittings in the cars are 3/8" UNF.
Posted 07 August 2018 - 06:34 PM
