Engine Covered In Oil After 4 Miles.
#16
Posted 09 August 2018 - 09:40 PM
#17
Posted 09 August 2018 - 09:48 PM
Sometimes a good smack from a decent hammer is enough to get the collets out. This may well have happened in the past
Nope, valves have done only 12000 miles.
#18
Posted 09 August 2018 - 10:54 PM
Yes its the head of valve stem ,3 exhausts.
it looks the top of the valve stem has been deformed (mushroomed) from the rocker tip hitting it but it's not clear - can you get a photo showing it from a side view
what do the rocker tips over those valves look like, and is there any evidence of the valves having contacted the pistons ?
what's the history on the engine itself ? anything changed recently etc etc
#19
Posted 10 August 2018 - 06:15 AM
Posted 10 August 2018 - 06:20 AM
well and truly abused from the looks of it and a grease monkey for a mechanic
wouldn't worry about the valve stems at the mo they can be cleaned up when taken out.
Hammer is definitely not the way to go
if you haven't a valve spring compressor a G cramp and socket with the side ground out so u can get to collets will do the job
Looks like you need to go through all the valves measure them up
not surprised it was running rich
sheesh theres some ******* about
#21
Posted 10 August 2018 - 06:50 AM
cheaper option could be get another head
replacement valves and hours of labour could well outrun cost of another head
#22
Posted 16 August 2018 - 08:40 PM
No chain but a timing belt.
Posted 16 August 2018 - 08:44 PM
#24
Posted 16 August 2018 - 08:54 PM
#25
Posted 20 August 2018 - 01:11 PM
#26
Posted 20 August 2018 - 02:49 PM
Hi,
Looks like a full strip and rebuild then I'm afraid. Best thing to do now is get the bores measured at a machine shop and see if you need a rebore...
