I'm considering upgrading the 4 fuse fuse box to take blade fuses but i have noticed that the highest standard fuse on a Mini is 35 amp and it appears that a 35amp blade fuse is not available only 30 or 40 amp.
If this is the case would I go with a 30 or a 40 amp fuse?
Cheers.
Upgrading Fusebox To Blade Type Fuses
MinesRed
, Aug 08 2018 11:44 PM
5 replies to this topic
Posted 08 August 2018 - 11:44 PM
Posted 09 August 2018 - 02:57 AM
I've gone from the old 2 fuse to a 6 Blade Fuse box. Off hand, I think the biggest fuse in there is a 10 amp.
Posted 09 August 2018 - 11:36 AM
Some interesting yet daunting reading.
So,as a result I will either remove and clean or replace the standard fuse box OR fit a 'plug n play' system made by Wired by Wilson.
This is a nice neat alternative,has anyone had the pleasure of fitting one?
Ta.
Ta.
Posted 09 August 2018 - 04:47 PM
I can highly recommend Wired by Wilson fuse box I simply sent David a picture of my old fuse box, he then made one with two extra fuses for stereo and USB/cigarette lighter socket and if was a straight swop.
