How Long To Refill Cooling System?
23 replies to this topic
#16 Icey
Icey
  • 1,493 posts
Posted 10 August 2018 - 04:19 PM
Also tap water from my taps will fur up a rad pretty quick!
You can lay bricks with our water but never seen any evidence of ill effects in any of our cars, new and old.
#17 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 10 August 2018 - 05:19 PM
Our Scottish water runs clear, it's generally considered as a soft water ?
Edited by cal844, 10 August 2018 - 05:19 PM.
#18 luismx123
luismx123
  • 525 posts
Posted 10 August 2018 - 06:28 PM
Well I randomly checked the radiator today...had to add 0.5L into it... and i dont see any dripping underneath... im lost. MOT equivalent is in 2 weeks and will swap the whole rad setup once i pass - or if i pass....
Water antifreeze do i add? the green or the red? or is it blue? one?
#19 Carlos W
Carlos W
  • 10,110 posts
Posted 10 August 2018 - 07:34 PM
Are the carpets dry?
#20 luismx123
luismx123
  • 525 posts
Posted 10 August 2018 - 09:16 PM
 will check tomorrow but havnt seen/felt anything yet... was crawling around today installing a new throttle cable and didnt notice anything. will give it a closer look.
#21 Carlos W
Carlos W
  • 10,110 posts
Posted 11 August 2018 - 07:11 AM
Just wondering if the heater matrix may be leaking
#22 zero_wlv
zero_wlv
  • 126 posts
Posted 11 August 2018 - 08:32 AM
If the OP (or one of their neighbours) has a dehumidifier at home, this will produce distilled water, free of calcium. I've used this in the past when I've had no coolant handy.
#23 luismx123
luismx123
  • 525 posts
Posted 11 August 2018 - 01:06 PM
i can buy some its not an issue :P Just more of a - what can i get too before my motor burns type of thing :P
I found a wetspot under the rad... kinda dripping onto the subframe. didnt have time to check if it was a hose or a leaky rad... gonna look closer tomorrow!
#24 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 11 August 2018 - 01:16 PM
That may well have been the cause of the overheating in the 1st place; hose / connection / or core
At least you have narrowed it down now
