Keeps Coking Up / Breaking Down - 998
Posted 11 August 2018 - 12:53 PM
It's OK on long journeys did London to Brighton and was booting it it was fine
I've had someone who used to work on minis give the carb a little tune he said it's fine it seemed to rev and go much better to be honest, on a long journey it was fine but around town it just soots up,
It's got a stage 3 head and the stage one kit I think? Rc40 exhaust, K&n filter with drilled airbox different needle minispares inlet manifold,
Want to drive it about but bit annoying that it keeps breaking down!
The vacuum advance pipe where it goes into the Dizzy the rubber is a little broken up,
The points etc look ok,
Basically the car was sitting in a garage since 2003,
Posted 11 August 2018 - 12:57 PM
get it set up correctly on a rolling road or as you are london based i would see when AcDodd is next doing a mobile set up session
like this one
http://www.theminifo...dd#entry3547803
Posted 11 August 2018 - 01:15 PM
Posted 11 August 2018 - 02:33 PM
Hi,
Check the float valve is sealing fully.
Posted 11 August 2018 - 04:05 PM
as above - check choke is returning fully
it's easy to adjust it so it is too tight / slightly on
Is it a HIF carb (float under the carb) ? make sure you are turning the screw out to weaken (opposite to what you would think)
what needle has it got , is it correctly seated ? AAA is a good needle to start with
vac advance pipe is dirt cheap - https://www.ebay.co....5.c100005.m1851
Edited by sledgehammer, 11 August 2018 - 04:17 PM.
Posted 11 August 2018 - 04:55 PM
There was someone who mentioned that there was a mini specialist in London with a rolling road as well? Can't remember who it was though
